This command configures the amount and type of data that is included in the status report for a collector.
| all | Configures report data set for all existing collectors. |
| hostname | Specifies the host name of the collector. |
| ip_address | Specifies the IPv4 address of the collector. |
| data-set | Specifies the report data set. The default is detail. |
| detail | Specifies the output of show tech-support area for area general, config, log, VLAN, and EPM. |
| summary | Specifies the output of show tech-support all command. |
This command configures the amount and type of data that is included in the status report for a collector. When you specify all, it configures a report data set for all existing collectors; otherwise report data is set for a particular collector specified by the hostname or IP address. When the data set is set to summary, the status report sent by the switch includes installed ExtremeXOS and Bootrom image versions, the active partition, serial number, equipment type, installed hardware options, stored SRAM contents, basic switch configuration, and log messages. The output of the summary option is collected from the show tech-support area command for the area general, configuration, log, VLAN, and EPM. Changing the report data set to detail will send the full output of the show tech command. When a collector is added, the data set is set to detail.
The following command example configures a specific collector to display a detailed output set:
configure tech-support collector 65.222.234.14 data-set detail
This command was first available in ExtremeXOS 15.4.
